Explode symbol without losing symbol attributes?
Hi
I want to explode all the drawings before issuing the drawing package to clients. In Autocad, it has the function called special explode (AEEXPLODE), the detail of the function is that : Explodes attributes and blocks to geometry and text entities while maintaining the value previously defined in the attributes. You can take advantage of the tagging tools to modify the text entities to attributes and the linking tools to make various blocks.
I am wondering if there is any similar function in Promis.e.
Thank you,
Yi
