If all of the available children symbols have been added to a parent/family in schematic, is there an easy way to move the child to another selection? For example, a 4 pole relay coil and all 4 N.O. child symbols have been added but I want to move the contact (connection point numbers) by swapping the children around, there is not a good way to do this. If it is not entirely filled, say only 3 of the child symbols have been used, I can easily drag and drop in the Device Usage Chart. If the family is full, I otherwise need to remove a contact out of schematic completely, then move the remaining ones, and re-add in the N.O. contact back into schematic. Is there a better workaround?
Answer Verified By: MagEngineerAaron
