I've been fooling around in promis-e for the first time in years and it's just as I remember, however I have a really annoying issue.
I have a wire label that refuses to be deleted. I want the number assigned, I just don't want it shown on this particular branch.
The label was assigned automatically (not sure why it appeared on this branch either by the way). It always comes back on page update.
Here's what I've tried.
I went into the database and removed the record from wirenotext table (both manually and using the stored procedure) same issue.
Any Ideas?
First I'd try Update Page and Validate Page if you have not done so already.
If the wire number text remains after deleting the wire or deleting all wire numbers in the project, the text seems to be no longer associated with a wire but still programmatically protected by promis.e. You could try using some of the methods described in the Delete Remnants of a Symbol article.
Answer Verified By: Matt_P
