Multiple Placement with Fuses
I am having an issue when I try to use multiple placement in panel layout with my fuse symbol. I have fuse part numbers and I have fuse holder part numbers both are needed to get the desirable information on the schematic and on our labels that we use. The problem is that in order to get the fuse description information such as amps and voltage the fuse needs to be the primary part number in the schematic. When you do that the fuse holder is the part that is used to place the layout on the panel. Since the fuse is the primary part number it does not allow you to use multiple placement in panel layout, because the fuse holder is not the primary part number in the schematic. Is there a work around for this?
