Is there a way to update multiple macros at once? I have 500+ macros that are similar but all hold different part numbers and symbol variations. A vendor update a part that no longer need an add-on part associated with each macro. I need to remove the add-on part from each macro.
Alternatively, is there a way to place multiple macros in a single page at once and then I can do a find-replace type function page-wide? I realize this method I'd still need to manually save each individually, but it is one step closer and a big time saver.
Aaron
Hi Aaron. There's really no way to modify a macro other than placing it, making the changes, then creating it again. So if you already have a list of macros you need to change, using Project API Builder to do so is nice way to place the macros. After placing the macros one way or another, I did not find a way remove the unwanted part number other than the method you were trying to avoid:
SCRIPT 3 just allows for more parameters for the SYM instruction. There is a "cheat sheet" for Project API Builder on your system, typically located in a path such as:C:\Program Files (x86)\Bentley\promise V8i\promise\promise\plugins\ProjectAPIBuilder\xlsapiformats.xls
This file describes the parameters for the different SCRIPT versions.
Answer Verified By: MagEngineerAaron
