Is it possible to not show wire link index?
Answer Verified By: Frédéric Couillard-Proulx
Hi Matt,
Thank you for your answer. I'm new with promise.
I think it may be a symbol creation problem. Here are the symbol that I use.
When I link this wire link with an other I automatically got this text but I don't want it.
The only way to hide it that people know in my team is to set the text very small.
Do you know how to solve this problem? May you teach me how to modify a symbol?
Thank you
I try to set everythings identic and it still not working.
It is never working even when I create a symbol from scratch. I think it may be my project template? WDT?
So you found an ANSI_IEEE_2D template file to use? Or you checked the working units in your template file and set them the way Matt suggested? Really I just strongly recommend that you update to the current version of the software instead so you have all the latest version files. Select Series 8 has been out for a while and is on the second release, while the SS5 version you listed is from around 2011, so there have been many updates and changes since then. Also, you should not be using the Handles to move anything in Promis.e. You should be using the Move command as designed in the right click menu or in the Task Bar commands. Trying to manipulate symbols and wires with Handles can corrupt your drawings.
I change the working unit. I didn't found the ANSI_IEEE_2D.
I really want to change the version but I need to wait for the IT team (and it is always long). I think it would solve all my symbols problems.
Anyway, I just think I'm going to wait and try to work without the handles.
Thank you guys
Well if you are currently using a version from 2011, then I would agree it seems to take your IT department a long time to update your software.
Yeah so long! I'm new in the electric department so I'll give a try
