Hello everyone!
I am starting to use Promis.e and wanted to ask about the ladder command. When I want to placer the ladder, the only option I have to placer it the first time is with the steps vertical and the two main segments horizontal. I then need to rotate and stretch as needed. ¿is there a way to placer the ladder "vertically" automatically? Below there are two figures with the expectation and the reality.
Thanks a lot.
Expectation Reality
The ladder direction is based on the Drawing Standard that you are using for the project. If you are using ANSI based English standard then the ladder is like your "expectation" picture. If you are using IEC metric drawing standard the ladder is like your "reality" picture.
Answer Verified By: Christian Acevedo
Nevermind, just found it. Thank you so much.
