I have a problem when I want to place a symbol that I created there is no device properties window prompt. In which setting shall I set?
What command are you using to insert the symbol, and what type of symbol is it? Starting with Select Series 8 we simplified the Insert Substation Object procedure to accommodate user requests:
So if you want to see the Device Properties after you insert the symbol you can right click the symbol and select Device ID from the shortcut menu that pops up.
Another possibility if you are not using this method to insert the symbol, is that the symbol you created does not have a Device ID attribute on it. You could check this in Symbol Creation, or if you right click on the symbol and are not able to Select Device ID, then there isn't one on the symbol.
