Help with Error Message
Receive the above message when I go to open PromisE program. Any help would be greatly appreciated.
  • Hi Dan. Since the error message includes "UserSettings", the first thing I would try is closing Promis.e then renaming the per-user application data folder for Promis.e. You should see a new folder get created when you next start Promis.e, with fresh files added as needed.
    If that doesn't help, you can rename the folder back again. And in that case it might be helpful to get the contents of the C:\ProgramData\Bentley\Promise V8i\Config\LastError.txt file.
    Internal Error
    UI Error Message: Object reference not set to an instance of an object.
    TargetSite: Boolean Init()
    DeclaringType: ECT.ECAD.API.UserSettings
    Attributes: public
    MemberType: Method
    StackTrace: C:\ProgramData\Bentley\Promise V8i\Config\LastError.txt
    Product Version: Promise V8i (SELECTseries 8)
