Now, we start to design two (2) new 110kV substation, as below:
Please you help us for this, could you give to us the flow chart for design, then we will follow your guide line.
Hi Bao. These are broad questions which do not really have answers that suit everybody, and I'm not aware of a flow chart that would provide answers either.
You may want to watch the QuickStart for Bentley Substation, which you can access on the LEARNserver or via CONNECT Advisor, and take the courses available in the Bentley Substation 3D Physical Site Designer Learning Path. This learning path should answer your "how to design a new substation" question.
For existing substations designed outside of Bentley Substation, you can import existing drawings into Bentley Substation using the Import Drawings tool, then use the skills learned for creating new substations to add components to the project.
Additionally, you can contact your Bentley account representative and ask about arranging for training and coaching.
Dear Mr. Matt_P,
Thank you for your information, can you help me as Advisor? from 2D design, you develop it 3D design.
Yes, we can try to help. What is the question or issue?
We will do design by 2D Autocad, You guide us to build it by Benltey.
