Hi In my computer, there are two users, in one user, the Promis-E is working already but in the other new recently created user, with the same file path and setting the promis -e is not able to connect to SQL and show "Configuration not saved:No version resource could be located in database. Project schema is invalid" error while setup.
Could anyone please help to configure the Project setup in the new user.
Hi Prashant. If you compare the Promis.e Setup > Project Database dialog when you are logged in compared to when the other user is logged in, are the settings the same? In particular, what authentication method is each of you using (Windows Authentication or SQL Authentication)? If using SQL Authentication, are you using the same Login?
The problem could be that the other user is pointing to a different database or they are using a different login that is unable to read the Version property of the database. See the Error - No version resource could be located in database article.
Hi Matt,
Thanks for quick reply. The setting on the both users were same and both were using the windows authentication. But, by going in the authentication, i found that the particular databases are not having updates and creation rights in the SQL database, so I have updated the rights from the SQL Management Studio for new user and now it is working. Anyways, Thanks after seeing your answer I got the the links of resolution.
