Hi everyone, i got a problem when i tried to import the symbol which i did create!
As you can see the Part number tab is blank and when i click in the ... at the end i can not find any part number for this symbol
It still doesn't have the part number while i did create one in the parts database manager and also the accessory kits manager.
Can someone help me to figure it out! Thank you and sorry for my bad in english :(
When you created the Part Number did you also put the name of the symbol that you wanted to associate it with in the field for Symbol Name? Do you have the correct Part Type?Another issue might be if the Part number had been used in the Project and then edited to add more information. When you do that, you typically have to Update the Part number definition that is used in the project: https://communities.bentley.com/products/electrical___instrumentation/w/electrical_and_instrumentation__wiki/5348/parts-database-changes-not-reflected-in-project
Thank you so much! I forgot to set SGL at the Part type field.
