The "Thomas & Betts Cable Ladder Aluminum" (CAT_Thomas_Betts_Cable_Ladder_Aluminum.xml) catalog is missing 12" reducers (Left, Right, Straight).
Catalog Link: http://tnb.ca/en/pdf-catalogues/cable-tray-systems/tnb-cable-tray/
Hi Patrick. Thank you for reporting this. Is this problem limited to ladder with 6" height?
Hi Matt. There is different behaviors depending of width and depth selected for the same catalog.
For 6" wide by 4" height, I have the option to enter any value. It would have been more appropriate for the generic catalog.
For 6" wide by 5" height, it's ok. A dropdown list with all valid values.
For 6" wide by 7" height, there is a dropdown list like this (9, 12, 18, 24, 30, 36, 42, 9, 12, 18, 24, 30, 36, 42). So duplicate values need to be removed.
I have not checked width higher than 6".
Patrick, I have reported this as defect TFS 770706. Since the problem is solely in the dataset (as far as I can tell) it should be possible to fix it by modifying the dataset. Specifically, by correcting the CAT_Thomas_Betts_Cable_Ladder_Aluminum.xml file. I'm working on this now.
And for other readers, here's the corrected CAT_Thomas_Betts_Cable_Ladder_Aluminum.xml file:
3872.CAT_Thomas_Betts_Cable_Ladder_Aluminum.zip
Answer Verified By: Patrick Loiselle
