Oracle parts database in a sql implementation??
Hello all, we have a sql implementation of Promis.e/Substation. Does anyone know if we can connect Promis.e to an Oracle parts database?
  • Hi Trevor,
    You can add a new Parts database path from the Setup dialog under System Paths tab. While adding a new path, first provide a name for the new parts database then select the Use Connection String radio button and click on Build. In the dialog that pops up, click on the drop down for Database Type and select Oracle. By providing the correct User Name, Password and Server Name  you can connect to the Oracle database and create a new parts database path. You can refer the attached image.
    Sarvesh
