I've downloaded multiple Catalogues & Part Number Databases from Bentley Portal. Now, I've successfully added the catalogues and now I've multiple Part Number Databases. Like one Database for Siemens one for Weidmuller etc... How can I add/load multiple Databases into Promis.e?
Hi Masood,You can either add a new parts database or merge part number records from manufacturer parts databases into the main parts database used by the software.You can add a new parts database by using the New Parts database path option under System Paths tab from the Setup dialog. Refer the image below.If you want to merge the new part numbers in existing database, use the Parts Database Merge Utility. Refer the below mentioned Wiki link for the same.Parts Database Merge Utility: https://communities.bentley.com/products/electrical___instrumentation/w/electrical_and_instrumentation__wiki/23939/parts-database-merge-utilityHope this helps.Regards | Sarvesh KulkarniProduct Engineer - Bentley SystemsAre you a CONNECTED User? Click here to find out moreProduce 3D models of existing conditions and Bring them to life !
Thank you Sarvesh.
