WHEN generating a new 3d dgn file, all four views default to "top" view only. Holding down the view rotation icon lists only the top view, no others....even though the seed file lists all views for selection. Is it possible to correct this?
Hi Larry. Which software is this question regarding? I'm wondering if the software is actually using the seed file you think it is using.
As far as the Top view icon only being available under View Rotation, try holding down the View Rotation button and selecting Open As ToolBox. Right-click any button on the resulting tool box and click the names missing buttons to place a check mark next to their names, enabling them. I'm not sure this is the answer since you mentioned all the buttons were available when looking at the seed file.
You may need to toggle the View off and on to see the missing buttons appear after enabling them.
thanks very much...didn't find too much direction in the help directory regarding this but your answer worked great. Much appreciated!
