I would like to create IFC file with cable routes design created in BRCM software. I tried to do it using AECOsim Building Designer v8i but it does not work as I expected: in final IFC file I do not have any additional object properties (length, manufacturer, part name etc.). Is it possible to create it in easy way or I just have to use AECOsim to design cable routes?
Hi Mateusz, can you provide more details about the IFC file you want to create? I am not familiar with those.
