When I apply a clip volume to my view it my display styles doesn't show correctly what gives?
Hi Dennis. Can you describe what is happening for you and perhaps include a screen shot? This is regarding Bentley Substation, correct?
My display style is not showing correctly when I apply a clip volume. Attached above left is wrong above right is what I want it to look like
Dennis, first set the Usable for Clip Volumes check box for the display style on the Settings > Display Styles dialog:
Then, after applying a clip volume, there should be a Clip Volume Settings area on the View Attributes dialog where you can set the display style as desired:
Answer Verified By: Dennis Haselhoff
Thanks exactly what I needed. I'm pretty green to micro station as you probably realize
Great, thanks for letting me know. I've updated the Display hidden lines as dashed article.
