We are trying to integrate Promise with Projectwise however the "enable projectwise integration" check box is greyed out which is not enabling us to modify any of the config related to projectwise.
Hi Rather! Is the ProjectWise Explorer custom module installed ? I believe if the custom module is not installed, the "Enable ProjectWise Integration" check box will be grayed out. A compatible ProjectWise Explorer must be installed before you can install the custom module, of course. See the Install the ProjectWise custom module for ProjectWise Explorer article.See also the Configure button is grayed out on Setup - ProjectWise article.
