When I open V8i my project manger has stopped opening up, when I click on the project manager tab it will not open. the main drawing page opens fine but I am unable to select a drawing because I cant access the project manager I have worked with V8i on this computer for over a year and have never had this issue.
I have shut down the PC a few time now and no change. Any ideas?
I can't read the error message in the screen shot. Can you send a close up of the error message or type it in so we can see what error you are getting?
That exact error is listed in this wiki:
https://communities.bentley.com/products/electrical___instrumentation/w/electrical_and_instrumentation__wiki/17072/error-at-startup-the-type-initializer-for-ect-ecad-ui-shapemanager-threw-an-exception
Just so you know, you can type a few key words from any error message you receive into the search bar at the top of this page to see if there are any known solutions for any given error. Please try the solution listed and let us know if that resolves the issue for you.
