Product: Promis.e V8i (SELECTseries 8)
Version: 08.11.13.96 (Standalone)
I'm trying to create a report to EXCEL to break up my BOM by location to multiple sheets, then OLE object them into a Panel Layout Drawings.
Using the Group Footer page break works for the preview, but in XLS it only adds a row. How do I make the template designer create multiple sheets?
Attached is the report so far.
Thank you.
Hi Stephen. Try this:
Of course, since it is possible to copy and paste selected cells from Excel onto a drawing, an alternative would be to export to a single sheet then select the desired cells to copy, instead of exporting multiple, Location-specific sheets.
Answer Verified By: Stephen Waggaman
