In my substation project, I have individually created each bay on separate pages. The grounding grid for both the bays I'm creating on a new page and have referenced each bay in to connect the components to the grounding grid. I now have to create construction drawings for the earthing details, i.e. the connections of all the components to the grounding grid and for that I've taken a clip volume from the grounding grid page, with the reference for each bay included. In the construction drawings when I reference in the clip volume, I can only see the grounding grid section and the component which was referenced in the grounding grid page does not show and so i have to reference in the component separately to the construction drawing.
Is there anyway i can get both the grounding grid along with the component in one reference?
Thank you,
Kesigan
Hi Kesigan. Does setting Nested Attachments to "Live Nesting" on the Reference Attachment Settings dialog for the referenced clip volume in the construction drawing help? You may also need to adjust the Nesting Depth value as well, but I don't think so based on your description.
Answer Verified By: Kesigan Paramanayakam
Hi Matt,
Worked like a charm, thanks a lot!
