Cant use same wire number even if installation and location is different. Is it even possible?
I cant seem to use the same wire tag even if I change the installation and location to be different, shown in the picture below. I was assuming wire tags work like device IDs where you can have the same device ID if you have different installation/locations. So is it possible to have the same wire tag, or am I doing something incorrect?
Thanks in advance
