Good Day
I am busy working on customizing a report in Bentley Substation. Currently i have managed to customize the report to output all the parts used in a project, quantity and cost them. Now i am looking to further customize the report to break it down per discipline (i.e. structures, foundations, equipment etc.) - see below.
The problem that i am finding is that it i cannot apply a filter under the field column to select "Discipline". Why is this the case?
All comments or suggestions will be welcomed.
Mohammad
Hi Matt
Thanks for the prompt response. I find it very strange that all other fields are accessible in the filter besides "Discipline". What was the reasoning for this? By filtering by Discipline one could easy breakdown reports for for the various disciplines involved in Substation Engineering (Earth Mat, Terrace, Foundation, Steelwork etc.).
The predefined report type being used is "Bill of Materials (Quantified)"
Kind Regards
Bentley Substation v8i (SELECTseries 8)Version Number: 08.11.13.140
I agree that including a Discipline field in the BOM reports would be useful, so I've submitted a request for this to be included in a future release. The tracking number is TFS 862870; I will send a separate confirmation email to you.
In the meantime, adding Discipline to the "Bill of Materials (Quantified)" report is simple since the Discipline value is read from the same table as most of the other data in the report. So you could add "PartNumber.Discipline" to the SELECT statement in the rep_QtyOfBOM stored procedure in the project database.
Alternatively, you could create a new report template using Report Template Designer , choose the Customized By SQL Statement option on the New Report Template dialog, and paste in the query below. This will create a report template that has a column for each field in the query, so you will need to remove unwanted columns and format the template as desired if you use this method.
SELECT GetRepDevPartNo.Installation, GetRepDevPartNo.Installation_ANUM, GetRepDevPartNo.Location, GetRepDevPartNo.Location_ANUM, GetRepDevPartNo.id,GetRepDevPartNo.DeviceTag, GetRepDevPartNo.DeviceTag_ANUM, GetRepDevPartNo.partnumber, GetRepDevPartNo.balloon, GetRepDevPartNo.balloon_ANUM, GetRepDevPartNo.type, GetRepDevPartNo.quantity AS QUANTITY, .0 AS spare, PartNumber.Quantity_Per_Unit, PartNumber.Category, PartNumber.Manufacturer, PartNumber.Catalog_Number, PartNumber.Supplier, PartNumber.Part_type, PartNumber.Use_Unit, PartNumber.Order_Unit, PartNumber.Detailed_Description1, PartNumber.Detailed_Description2, PartNumber.Detailed_Description3, PartNumber.Detailed_Description4, PartNumber.Detailed_Description5, PartNumber.X, PartNumber.Y, PartNumber.Z, PartNumber.Weight, PartNumber.Power_Consumption, PartNumber.Selling_Price, PartNumber.Buying_Price AS BUYING_PRICE, PartNumber.Discount AS DISCOUNT, PartNumber.Assembly_Time, PartNumber.Wiring_Time, PartNumber.hour_cost, PartNumber.Additional_Part, PartNumber.Date_Created, PartNumber.Date_Modified, PartNumber.Device_Family, PartNumber.Attribute_Text, PartNumber.Single_Wire_Connection, PartNumber.Schematic_Symbol, PartNumber.Layout_Symbol, PartNumber.Wire_Diagram_Symbol, PartNumber.Hydraulic_Symbol, PartNumber.Pneumatic_Symbol, PartNumber.Single_Line_Symbol, PartNumber.Graphical_Plan_Symbol, PartNumber.Percent_Spare, PartNumber.Discipline,PartNumber.user1,PartNumber.user2,PartNumber.user3,PartNumber.user4,PartNumber.user5,PartNumber.user6,PartNumber.user7,PartNumber.user8,PartNumber.user9,PartNumber.user10,PartNumber.user11,PartNumber.user12, PartNumber.user13,PartNumber.user14,PartNumber.user15,PartNumber.user16,PartNumber.user17,PartNumber.user18,PartNumber.user19,PartNumber.user20,PartNumber.user21,PartNumber.user22,PartNumber.user23,PartNumber.user24,PartNumber.user25,PartNumber.user26,PartNumber.user27,PartNumber.user28,PartNumber.user29,PartNumber.user30,PartNumber.user31,PartNumber.user32,PartNumber.user33,PartNumber.user34,PartNumber.user35,PartNumber.user36,PartNumber.user37,PartNumber.user38,PartNumber.user39,PartNumber.user40,PartNumber.user41, PartNumber.user42,PartNumber.user43,PartNumber.user44,PartNumber.user45 FROM PartNumber RIGHT OUTER JOIN GetRepDevPartNo ON PartNumber.project_id = GetRepDevPartNo.project_id AND PartNumber.part_number = GetRepDevPartNo.partnumber WHERE GetRepDevPartNo.project_id=@projectid
