In Promis.e, every time I right click on an item, I get a small 'sub' menu that covers the main menu. This 'sub' menu has to be 'reset' in order to see the main menu. I didn't have this 'sub' menu until about a month ago when Promis.e was shut down incorrectly during an automatic restart after an unrelated software update. Can anyone tell me how to eliminate this 'sub' menu?
That is the MiscroStation context menu. It comes up when the right click is held longer than the time set in the options. You can read this wiki on how to adjust the time to its maximum value to help prevent that from coming up, but also try to remember not to hold the right click for too long. That is one of the first things I change when I get a new install:
communities.bentley.com/.../empty-box-is-stuck-on-the-screen
Answer Verified By: Mike Monds
Yes, that worked. Thanks Tani_S, that has been driving me crazy!
