When I try to auto-connect cables, the following error message appears in the object status " Object not found in the project model"? as shown below
Although the equipment are mapped and there is CADObject identification for each equipment.
Hi Nikolaos,Can try importing Cable & Equipment List again, And also check if the Equipment 11BBA-O/G15 is Present on the DGN where Equipment's are placed.Regards,Satish Saptasagar
I try with the same results. Is there error log for BRCM where could I figure out more details about this error?
