I am getting this error when I try to run my graphical part list.
Please help.
Below are the error message I'm getting
Unable to load/create dialog item of type 'IconPopup', id = -12203 from dialog ""
Unable to load/create dialog item of type 'IconPopup', id = -12203 from dialog "Window"
File [C:\PROGRAMDATA\BENTLEY\SUBSTATION V8I\SUBSTATION DATA\MY PROJECTS\33KV MRT2 BBP (25.05.18)\33KV-H-144800-06.DGN] saved
Locks=AS,PS,GG,GR,SN,ACS
File [C:\PROGRAMDATA\BENTLEY\SUBSTATION V8I\SUBSTATION DATA\MY PROJECTS\33KV MRT2 BBP (25.05.18)\33KV-H-144800-03.DGN] saved
Locks=AS,GG,GR,SN
File [C:\PROGRAMDATA\BENTLEY\SUBSTATION V8I\SUBSTATION DATA\MY PROJECTS\33KV MRT2 BBP (25.05.18)\33KV-H-144800-20.DGN] saved
File [C:\PROGRAMDATA\BENTLEY\SUBSTATION V8I\SUBSTATION DATA\MY PROJECTS\33KV MRT2 BBP (25.05.18)\33KV-H-144800-19.DGN] saved
File [C:\PROGRAMDATA\BENTLEY\SUBSTATION V8I\SUBSTATION DATA\MY PROJECTS\33KV MRT2 BBP (25.05.18)\33KV-H-144800-18.DGN] saved
File [C:\PROGRAMDATA\BENTLEY\SUBSTATION V8I\SUBSTATION DATA\MY PROJECTS\33KV MRT2 BBP (25.05.18)\33KV-H-144800-17.DGN] saved
Locks=AS,GG,GR,SNFile [C:\PROGRAMDATA\BENTLEY\SUBSTATION V8I\SUBSTATION DATA\MY PROJECTS\33KV MRT2 BBP (25.05.18)\33KV-H-144800-17.DGN] saved
Locks=AS,GG,GR,SNUnable to load/create dialog item of type 'IconPopup', id = -12203 from dialog ""
File [C:\PROGRAMDATA\BENTLEY\SUBSTATION V8I\SUBSTATION DATA\MY PROJECTS\33KV MRT2 BBP (25.05.18)\33KV-H-144800-16.DGN] saved
File [C:\PROGRAMDATA\BENTLEY\SUBSTATION V8I\SUBSTATION DATA\MY PROJECTS\33KV MRT2 BBP (25.05.18)\33KV-H-144800-15.DGN] saved
File [C:\PROGRAMDATA\BENTLEY\SUBSTATION V8I\SUBSTATION DATA\MY PROJECTS\33KV MRT2 BBP (25.05.18)\33KV-H-144800-14.DGN] saved
File [C:\PROGRAMDATA\BENTLEY\SUBSTATION V8I\SUBSTATION DATA\MY PROJECTS\33KV MRT2 BBP (25.05.18)\33KV-H-144800-13.DGN] saved
Hi Sofia,Are you getting this error for a specific project or the issue persists for all of your projects? Are you able to generate Graphical terminal plan for the Out Of The Box projects provided with the software? Are you able to open the Run Graphical Plan dialog? When exactly do you get the error message? Are the templates for graphical terminal plan as well as the symbol for it set correctly?Regards,Sarvesh KulkarniProduct Engineer - Bentley Systems
Hi Sarvesh,
Thank you for your reply, I noticed the error when I tried to run my GPL for all the projects, mind you that our GPL was a built-in plugin which helps to automatically run the GPL.
I don't know what causes it but I kept on getting error as below
I check the database, all symbol. header macro etc are available in the catalogue.
What is the major cause of the error ya ?
Hi Sofia,The information dialog indicates that the plugin is unable to place the macro in the drawing. It may be due to the macro not being in the location from where the plugin is configured to pick it up for placement or may be because the page where this macro should be placed is not getting created . I do not know how the plugin is configured to work, but one thing that you could check here is whether any changes made to the macro itself or whether the macro was somehow accidently moved from one catalog to the other. Also you can check whether the Page Format and Title Block which are used to create a new page for the placement of GPL are correct and exist in the catalog.Was this working fine for you previously? Were any other changes made recently to the catalogs or even to the priority of the catalogs in the Setup configuration. Also the errors that you have mentioned in the previous post, when are you getting those? Is it after you click OK on the Information dialog?Regards,Sarvesh KulkarniProduct Engineer - Bentley Systems
The error was popping out at the bottom of my page each time I run my GPL plugins. The result, yes the terminal function diagram came out, but I need to run a few time (until the software resolve itself) since the error (as per image earlier) kept on popped out.
I am certain that I used the right setup & catalogue as I did a cross check on the setup as well.
