While Promis.e is publishing my project i get this error message:
Please help.
Hi Edmund,The message that you are getting is similar to the one described in another forum post.https://communities.bentley.com/products/electrical___instrumentation/f/elcocad-promis-e-forum/118648/error-messageTo resolve the issue kindly first take a backup of your project using the Project Manager and then try Update Page. If this does not help, you can use Validate Page to find the error item and try to delete it. If you are getting this error, chances are Validate Page will return the same error. In that case you can try using Replace Symbol to replace the problem symbol with the same on the page.Regards,Sarvesh KulkarniProduct Engineer - Bentley Systems
Text of error message for searching purposes:
Publisher System NullRefererceException Object reference rot set to an instance of an object. at ECT.ECAD.API.RowItem.get_Name() at Bentley.Electrical.API.Base.LineXRefServiceBase.BuiIdLineXRef(Symbol fromSym, Symbol tosym, CrossRefSymboI cs, DataRow pglinkRow, Boolean hideDev) at Bentley.Electrical.API.Base.LineXRefServiceBase.InsertOrUpdateLineXRefText(Page pg, Cross RefSymbols nCrossRefSymbols, Symbols nSyms) at Bentley.Electrical.API.Base.LineXRefServiceBase.RefreshLineXRefText(Page pg) at ECT.ECAD.API.Project.RefreshAllPendingPages(Boolean updateWireLinkTarget) at ECT.ECAD.ECTPublisher.Form_publish.button_ok_Click(Object sender. EventArgs e)
Hi Sarvesh,
So I updated my page and I got this error message:
It doesn't tell me where the problem. Please help.
Also,
Can you clarify what the wire link symbol is? Can you let me know on this picture?
Hi Edmund,If you follow the below mentioned thread, you will find that the same issue was reported by another user and the issue was fixed by using Replace Symbol.https://communities.bentley.com/products/electrical___instrumentation/f/elcocad-promis-e-forum/118648/error-messageKindly go through the solution provided by Matt in the above mentioned thread and see whether it resolves your concern as well.Regards,Sarvesh
