I add terminals on the schematic, they show-up in the term-pin-plug-manager as I would think; then I add some devices like a circuit breaker on the wires connected to the terminals, and then I am seeing terminals with device ID: CB1, etc...
is this supposed to appear here?
Yes, If you look at the column titles, those are the Left and Right Target data. So the Terminal manager isn't just listing the Terminals, it lists the target devices to which the terminals connect in order to provide more information to the user about those terminals. The terminal data is listed in the middle columns.
Currently, I see the Device ID for the items left and right (I get that now), but apparently they chose to not show the Device Tag'ID for the terminal itself...
Robin Beltman Automation Engineer | Windemuller, Inc.
windemuller.us | 1176 Electric Avenue | Wayland, MI 49348 Automation | Communications & IT | Electrical | Outdoor Utilities | Renewable Energy ________________________________________________________________________
I would guess that when you open this Terminal strip in the Terminal Manager that you get a warning message telling you that you have invalid Terminal connections. This looks like you may have several devices connected in a daisy chain and the connections are going to the wrong CP's on the terminals. If you are using a standard 5 CP terminal, then there are typically 1 Internal connections (I), 1 External connections (E), and 2 Jumper connections (J) on the terminal symbol. You have connected the Circuit Breaker to a jumper, which is not allowed. You can only Jumper to other terminals, as the Jumper connection is meant to model the connection on a wafer style terminal where you would need to use a comb or clip jumper to connect it to other terminals in the same strip, and you can't attach a physical wire to those connections to connect to another device. If you fix the connections so that the circuit breaker connects to either an I or E connection., then the Terminal Manager will look better because you will have valid connections.
ok, thanks; now I understand a little more of this (why)...
