Dear Sir!
I have a question as below:
Want add a part number into a symbol, a part number must include Family of the symbol??
I creat Part number meet an error:
Please help me!
Để Add part number vào symbol thì chị vào trong Part database manager tạo part number rồi liên kết nó với symbol ở mục 3d layout trong phần symbol data nhé chị!! Và đừng quên set part type bằng SGL
ý chị hỏi là bắt buộc phải add symbol hay family vào device family khi tạo part number ấy? chị muốn hỏi không cần có được không thôi? chứ add thế mất công lắm
Bên em không xài cái family đó nên em không biết có cần không chị ạ !
Hi ,
To add the part number to the symbol, create a part number first then in part database manager, assign it with the symbol. Please follow the wiki link for the part type values https://communities.bentley.com/products/electrical___instrumentation/w/electrical_and_instrumentation__wiki/29886/part_5f00_type-filter-values.
That message is telling you that the symbol you have selected is not part of the Family that is associated with that Part Number you are trying to assign. For example, let's say that you are trying to assign Part number 123 to a Normally Closed Relay contact symbol. If Part Number 123 has been created in the Parts Database Manager to be associated with a Family, and that Family tells the software that Part 123 only has Normally Open contacts and has no Normally Closed contacts, then you would get that message. It says that you are using a symbol (normally closed) that doesn't work with the part number and family that the software was told would work. So the software is letting you know that there is a problem trying to link those particular items together.
You would need to change something to make those items work together better. You might chose a different symbol, a different part number, or you might need to do something to manage the items in the catalogs or Parts database to create a new combination of family, symbols, part numbers that fits the combination you are trying to use.
