Wiring
There was something changed recently where the wire snaps to the original start point all the time.
It is hard to do drawing when the wire is not continuing after clicking on a point or a device. I goes back to the original point and you have to click to stop then click again to start from the end point.
  • Please see attached
  • Hi Hocine,
    The issue that you are facing may be due to some recent update to AutoCAD, video drivers, or windows. Can you confirm for the same ? One possibility would be to find the recent change that was made and roll it back and see whether you then face the issue.
    Sarvesh Kulkarni
    Product Engineer - Bentley Systems
  • There were many mandatory updates on our Company and I can't bring it back.
  • Another user, also using a version of Promis.e that runs on AutoCAD, experienced the same problem recently. They ultimately found that a password management program was interferring with Promis.e.
    Try shutting unnecessary (to Promis.e) processes down. If that helps then it is a matter of determining which process is causing the problem. If the process is absolutely necessary, consider moving to Promis.e standalone. The problem may not occur with that version since it uses a different platform, and if it does occur  it may be possible (but not guaranteed) for us to fix it. Promis.e for AutoCAD is no longer developed so we cannot provide any fix that requires a change to that product.
