Here i add some raceway category.
But i don't know how to add layer.
ie. I want the HV raceway show in grey color in the model.
Hi there - you will get a faster response if you post in the appropriate forum. I will move your post.Regards
Duncan Brown
Hi Long Jun Deng.
Select Options > CAD Standards > Levels.
Click Add and add a level for the new voltage level.
In Options > Raceway Specifications > Level Assignment tab click Add.
Expand the new Overwrite.
Select the new level for the Level property and select the new voltage level for the Voltage Level Section 1 property. Set other properties if desired.
Answer Verified By: Long Jun Deng
Matt, thanks for your reply. It works.
