Greetings, I have the following problem, after modifying or creating an object I can not insert it since apparently it does not have a defined part number, which I would have to do to solve this problem, since due to this the objects that I have created or modified I can not use them. please someone who can help me.
Hi Johnny. You can place symbols without a corresponding part number by using Insert Symbol By Name.
To insert symbols using the Insert Substation Objects tool, you will want to associate symbols to part numbers. To create a part number record and associate symbols to part numbers, use Parts Database Manager. You would add the name of the schematic symbol to the Schematic_Symbol field and the name of the 3D Layout symbol to the Symbol_3D_Layout field, etc. Since you are using Bentley Substation, please also see the Parts missing from Insert Substation Objects article.
Thanks for the help I will try to be a little more explicit, after editing or creating an object, it is saved, the problem is when I try to insert it. By name, it does not allow me to see, the image in miniature and neither a part number, I think that the problem is that once I have created an object, it is necessary to assign a part number to that object, if that is how I assign a part number to an object that I have created or edited. Relice some captures to see if I can give me a better understanding ... Thank you very much
