After i insert the bend, there is no radius.
There is no R900 bend can selected in the horizontal/vertical bend-standard, If we can add it and how to add?
You can add new fittings or add radii to existing fittings using the Raceway Catalog Creation tool in Edit mode. The Raceway Catalog Creation tool is found in the BRCM Setup workflow in Tasks.
You may want to make a backup copy of your dataset before modifying it.
Matt, Thanks for your help.
