I have got the cableway catalog from Oglaend.
How can i import in BRCM?
Dear Long,Typically all the raceway catalogs are in the below mentioned locations.Imperial: C:\ProgramData\Bentley\BRCM\WorkSpace\Projects\datasets\imperial\std_dataset\racewayMetric: C:\ProgramData\Bentley\BRCM\WorkSpace\Projects\datasets\metric\std_dataset\racewayThese paths may be different if you have installed BRCM in a different directory and not in the default one.To import the catalog that you have, you need to copy all the files to appropriate directory mentioned above. Kindly note that you need to copy out the contents of the various folders as well. This is because all the CAT and DNA files should be in the root of '\raceway' folder. After that you need to add the entry for the Oglaend catalog in the LIB_Raceway.xml.Regards,Sarvesh Kulkarni
Answer Verified By: Long Jun Deng
Dear Sarvesh,
Thanks for your guide.
Now it works.
Dear Long,Glad to know that it has worked for you ! Regards,Sarvesh Kulkarni
