Dear Sir!
When I create new page, number page is not automaticly increase. Although, I use only a title block in project.
Please let me know the solution for this problem.
Thank you very much!
Hi Huong,Can you please share the screen shot of project manager where we can able to see the page number is not increase automatically and the pop up of New Page dialog while creating new page?
This is the first picture when I creat new page. But I change text of drawing set, Page number is not increase.
The Page Name field is typically set to the next available number for the specified Drawing Set automatically. If you are on the New Page dialog and specify a different Drawing Set, you need to click out of the Drawing Set field to apply that selection and see the Page Name change (when appropriate). Also keep in mind that if there is a page 1 and a page P202 in a drawing set is P202, the software considers the next available number to be 2, not P203.
yes! I want to next page : P202. Because I have a previous page : P201, but as I did, When creat new page, if I dont change description of Drawing Set , next page automatically : P202, but I change it, next page automaticaly is 1. I dont known where I had an error in setting.
Huong, on the New Page dialog you are specifying a different Drawing Set. Drawing Set is not just a description field. Since page numbers are drawing set based, you can have page P201 in drawing set A and a page 201 in drawing set B. Consider this sequence of events:
This is normal behavior. If you want sequential page numbers with only one instance of each page number regardless of drawing set, you simply need to enter the desired page number on New Page or Rename Page.
Yeah Sir!
Thank you so much!
