BRCM V8i crahses every single time I try to open the output manager.
What could be the reason of this problem?
I could succesfully update the BRCM database before.
You'll get better-informed answers if you post to the elcoCAD|Promis.e Forum.
How can I move my question to that forum?
Philipp Holenstein said:How can I move my question to that forum?
Click the More button under your post. You should see a Move option.
Hi Philipp,I believe you have raised a Service Request, SR #7000816984 for this concern. We can continue to investigate and discuss this issue in the SR. Also, did you try to restore the platform defaults for BRCM ? The below Wiki Link may come handy.Regards,Sarvesh Kulkarni
Hi Sarvesh,Thank you for your response.I did follow all the steps from the Wiki and restored the defaults. But I am still encountering the same problem, the output manager doesn't open, instead the dialog box "BRCM has stopped working" appears.
Regards, Philipp
