Hi All,
This is probably a very basic question, but I am new to the Bentley BRCM/Microstation world:
I wanna moved the two marked cable trays, but I changed something or activated a setting, I just can't grab them..
Thanks in Advance
Hi Philipp,Click on the Element Selection command highlighted in the image below. You should be able to select things back again.Currently you have the move command selected, so you can move the already selected elements, but are unable to select any new elements.Regards,Sarvesh Kulkarni
Answer Verified By: Philipp Holenstein
Sarvesh Kulkarni said:so you can move the already selected elements
That is exactly what I am trying to do. Moving the two marked cable trays with the "move" command.But I can't, is it possible I activated some different moving mode?
Edit: I was in the Equipment drawing and attempted to move the cable trays, thank you Sarvesh for the the reply
Hi Philipp. Do I understand correctly that ultimately the problem was that you had and equipment DGN file open, and this file had a raceway DGN file attached as a reference, and that you were unable to move cable trays because they reside in the raceway DGN?
If so, then yes, that explains the behavior you were seeing. To move the cable trays you have two options:
Yes that is exactly what I was trying to do.Thank you for giving me an alternative, so I don't have to switch to the raceway drawing.
