Dear Sir!
I have an error as shot screen
When I am trying to work with us, but when I run report , at that, no somethings which apear in report drawing.
As above picture, i dont know what is this problem and solution for it>>
Hi Huong,
Huong Nguyen said:When I am trying to work with us, but when I run report , at that, no somethings which apear in report drawing.
I am not clear on what workflow you are doing before getting this error. This issue was reported earlier in the below mentioned community thread.As mentioned over there, you can try using Validate Page, Update Page or Rebuild Project Database options and see whether this issue gets resolved. Refer the below mentioned Wiki Links for the same.Regards,Sarvesh Kulkarni
