I've been using the same device tag ID(COIL) for many time in the same project , and been appended. How can i solve this problem? HELP PLEASE
Jacky, if I understand correctly, you assigned the same device ID to symbols that are supposed to represent different devices. It sounds like these are relay devices with families assigned. When prompted with "All instances of this symbol in the selected family have already been used in this project..." you chose Append. Is that correct? If so, then I think you have two options.
Option 1:
Option 2:
You may want to Backup your project before trying either option.
Answer Verified By: cheong jacky
