I enter in Bentley Substation:
When I create a new file or project, appear this error:
What can I do?
Hi Aitor. Your error message,
Internal ErrorUI Error Message: Not find x64 version Access Connectivity Engine!TargetSite: Int32 NewConnection_String(System.String)DeclaringType: MDBProxy.ProxyAttributes: public staticMemberType: MethodStackTrace: C:\ProgramData\Bentley\Bentley Substation CONNECT Edition\Configuration\Datasets\Substation\Config\LastError.txtProduct Version: Bentley Substation CONNECT Edition
sounds like the software cannot connect to a required Access database because 64-bit Microsoft Access or 64-bit Access Database Engine is not installed.
Do you have Microsoft Access installed? If so, is it 64-bit or 32-bit?
Hi Matt,
It,s already okey. I have downloated the AccessDataBaseEngine64 and runs perfect.
Answer Verified By: Matt_P
