Hi all.
I have to modify a very old plugin for Microstation V8 (2004) that uses EED (Elementary Electrical Diagrams).
I have to run this plugin into Microstation V8i SS3 and EED is not working.
Support by Bentley has expired many years ago for this software.
Does anyone have the source code?
Thanks in advance
Hi IronMonkey,Thank you for letting us know your concern.We are discussing internally what would be the best way forward and how we can assist you on this. We will get back to you as soon as we have some update.Regards,Sarvesh KulkarniProduct Engineer - Bentley Systems
Hi IronMonkey,I have been told: Elementary Electrical Diagrams was complied on MicroStation SS2, so EED requires MicroStation SS2 to install. But it is a MDL application so, it is not sensitive to the version of MicroStation (SS2/3/4). Hence you can follow below steps:1. Install MicroStation SS2 2. Install Elementary Electrical Diagrams 3. Uninstall MicroStation SS2 4. Install MicroStation SS3With this you may be able to use Elementary Electrical Diagrams with MicroStation SS3.Regards,Sarvesh KulkarniProduct Engineer - Bentley Systems
First of all… thank you very much for your answer!
But there is something strange in what you said...
My EED version is 8.2.2.8 and it is from 2003 as you can see in the attached picture.
Microstation V8i SS2 is from 2010 as you can see in the versions history. EED was built for Microstation V8 version (2001-2006).
https://communities.bentley.com/products/microstation/w/microstation__wiki/3164/history-of-microstation
