When i try to modify the drawing page, i get the message Title Block Name Invalid. It seems to come and go. Sometimes I am able to modify the drawing page and others times I can not.
Hi Ronald,You might be facing this issue due to the reason that because when you modify the Title Block the Title Block Specified might not be present in the currently loaded Catalog. The steps for the same and reference can be found in the below Wiki Link.Regards,Satish Saptasagar
That WIKI page seems to be for Bentley Substation. I am using Promis.e. The problem is also intermittent. I can try to open a new page and I get the error. Yesterday after about an hour and dozens of attempts, I was finally able to open a new page with the correct title block. Now I cannot open a new page without getting a title block invalid error.
Hi Ronald,The Wiki Link is for Promis.e and Substation.Are you facing this issue in a Project Restored on the machine recently or was Created in Promis.e on your machine.Can you confirm that the Title Block selected while Creating a New Page is Present in the Catalog. Kindly update us which will help us investigate the issue.Regards,Satish Saptasagar
I think that I figured it out. It was not in the Titleblocks catalog. It was in the projects catalog.
Answer Verified By: Satish Saptasagar
