I am looking for some templates ( not the ones OOTB ) for connections to show ( JB report f.i. ). This in autocad and in excell. This should show term-in / middle / term-out (as standard foreseen) , but also the instument/panel and stripnumber on the incoming side and outgoing side. Bit similar like the DCW.
thnx in advance !
Frank
Hi Frank,Just to confirm the template that you ae looking for is in Bentley Instrumentation and Wiring?Is the excel sheet generated from a software or was it created manually?Regards,Sarvesh KulkarniProduct Engineer - Bentley Systems
Hi Sarvesh,
Yes, the template would be to be used within Instrumentation end Wiring. And again yes, the excell was generated from I&W. I will attach the xls used or this purpose. Where TermconSweco.xls is my attempt to pull tag and panel to the template, and TermCon.xls is the standard delivered with Bentley.
Thnx for the quick response !
FrankTermConSweco.xlsTermCon.xls
Hi Frank,We are discussing your concern internally and will get back to you as soon as we have some update.Regards,Sarvesh KulkarniProduct Engineer - Bentley Systems
thnx !
