I have an issue where navigating to an older project (~1 year old), is currently showing pages of a recently completed project.
A couple of key points to note / things ive spotted;
Can anyone offer any help on what might the issue be?
Kind Regards
Hi Adam,Were both the projects, the old one as well as the new, created by restoring from a same project backup .prj file? Or was the new project created by copying pages from the old project into the new one?Regards,Sarvesh KulkarniProduct Engineer - Bentley Systems
I believe there is a high possibility that the user may have copied the older project to use as the newer project, however the user cannot recall exactly.
There has been some confusion around the correct projectproperties file to use, so my suspicion is that the projectproperties file was copied from older project to newer project. At the same time, I think the user may have copied the ctd.fid file?
This isnt confirmed, but it sounds likely to me?
Hi Adam,As you have mentioned that it might be due to the reason that user might have copied the ECT.fid file. But if the user is trying to Copy the Old Project Pages to New Project Page then they can copy the pages in Promis.e Project Manager which will make sure that the user doesn't copy ECT.fid file by mistake, the steps for the same can be followed in the below Wiki Link.Also you can select the required Project Option for a Project while creating and then copy Project pages in Project Manager which will be the correct work flow. Below is Wiki Link for Project Option.Regards,Satish Saptasagar
I have re-iterated the above to the engineer thank you.
But do you have any suggestions for linking our older project back to the original project?
Hi Adam,I was able to recreate your scenario by copying the ect.fid file from one project folder into another. I resolved the issue by changing the guid back to its original value in the ect.fid file of the affected project and also by matching the Project Id in ect.fid file with the one in the database.To elaborate on the solution, I had a project named GUID_COPIED in which I had copied the ect.fid file from another project. I changed the guid for this project in the ect.fid file as what was present in the database. Then I checked the Project Id in the database for this project and then changed the value in ect.fid file with the one in the database.In the database the Project Id was 1023. So, in the ect.fid file change the first line to have the Project Id as 1023.Regards,Sarvesh KulkarniProduct Engineer - Bentley Systems
