I tried to install BRCM Connect Edition but it failed at the installation of SQLEXPADV package.
Here is a copy of some lines of the log generated by the installation:
[02C8:0184][2019-02-01T10:10:50]e000: SQLEXPRADV is an OnDemand Package, downloaded path is cdnllnw.bentley.com/.../sqlexprwt_x86_enu.exe [02C8:0184][2019-02-01T10:10:50]i338: Acquiring package: SQLEXPRADV, payload: SQLEXPRADV, download from: cdnllnw.bentley.com/.../sqlexprwt_x86_enu.exe [02C8:0264][2019-02-01T10:11:16]i000: Installed package BrcmDocumentation [02C8:0264][2019-02-01T10:11:16]i319: Applied execute package: BrcmDocumentation, result: 0x0, restart: None [0AE4:02E4][2019-02-01T10:11:16]i325: Registering dependency: {22c47c98-979a-45a2-b4a8-0952c50e0e2c} on package provider: {1E159C06-C1CB-372E-BBDC-A25DD78A7582}, package: BrcmDocumentation [02C8:0264][2019-02-01T10:11:16]i000: Installing AccessDatabaseEngine [02C8:0264][2019-02-01T10:11:16]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;powerproductpackage;pointtools32extx86;brcmdocumentation;accessdatabaseengine' [0AE4:02E4][2019-02-01T10:11:16]i301: Applying execute package: AccessDatabaseEngine, action: Install, path: C:\ProgramData\Package Cache\277EA5EBCD18B8B98D82C9DC53399B4FE864CA51\AccessDatabaseEngine_x64.exe, arguments: '"C:\ProgramData\Package Cache\277EA5EBCD18B8B98D82C9DC53399B4FE864CA51\AccessDatabaseEngine_x64.exe" /q /norestart' [02C8:0264][2019-02-01T10:11:19]i000: Installed package AccessDatabaseEngine [02C8:0264][2019-02-01T10:11:19]i319: Applied execute package: AccessDatabaseEngine, result: 0x0, restart: None [0AE4:0250][2019-02-01T10:13:03]i305: Verified acquired payload: SQLEXPRADV at path: C:\ProgramData\Package Cache\.unverified\SQLEXPRADV, moving to: C:\ProgramData\Package Cache\9B9F0054139E678C8BB13A9BFF0FCD513015712C\SQLEXPRWT_x86_ENU.exe. [02C8:0264][2019-02-01T10:13:03]i000: Installing SQLEXPRADV [02C8:0264][2019-02-01T10:13:03]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;powerproductpackage;pointtools32extx86;brcmdocumentation;accessdatabaseengine;sqlexpradv' [0AE4:02E4][2019-02-01T10:13:03]i301: Applying execute package: SQLEXPRADV, action: Install, path: C:\ProgramData\Package Cache\9B9F0054139E678C8BB13A9BFF0FCD513015712C\SQLEXPRWT_x86_ENU.exe, arguments: '"C:\ProgramData\Package Cache\9B9F0054139E678C8BB13A9BFF0FCD513015712C\SQLEXPRWT_x86_ENU.exe" /q /IACCEPTSQLSERVERLICENSETERMS /ACTION=Install /INSTANCENAME=BENTLEYECAD /FEATURES=SQLEngine,SSMS /SECURITYMODE=SQL /SAPWD=BentleyEcadAdmin1 /SQLSYSADMINACCOUNTS="Builtin\Administrators" /SQLSVCACCOUNT="NT AUTHORITY\SYSTEM" /BROWSERSVCSTARTUPTYPE=Automatic /TCPENABLED=1' [0AE4:0250][2019-02-01T10:13:03]i304: Verified existing payload: BRCMDatabaseConfiguration at path: C:\ProgramData\Package Cache\77F1DFEB6796C988A8E14E68C6E5B656F4B548CE\LaunchSQLExpress.exe. [0AE4:0250][2019-02-01T10:13:03]i304: Verified existing payload: BRCMDs_Imperial_BundleModule at path: C:\ProgramData\Package Cache\{B5272D99-3760-3570-A35C-9D5590AC812F}v10.00.00.013\BRCMImperial_DSx64.msi. [0AE4:0250][2019-02-01T10:13:03]i304: Verified existing payload: BRCMDs_Metric_BundleModule at path: C:\ProgramData\Package Cache\{F8196469-556A-32FA-B65E-CB62AEFE812F}v10.00.00.013\BRCMMetric_DSx64.msi. [0AE4:02E4][2019-02-01T10:14:00]e000: Error 0x85940001: Process returned error: 0x85940001 [0AE4:02E4][2019-02-01T10:14:00]e000: Error 0x85940001: Failed to execute EXE package. [02C8:0264][2019-02-01T10:14:00]e000: Error 0x85940001: Failed to configure per-machine EXE package. [02C8:0264][2019-02-01T10:14:00]i000: Installed package SQLEXPRADV [02C8:0264][2019-02-01T10:14:00]i319: Applied execute package: SQLEXPRADV, result: 0x85940001, restart: None [02C8:0264][2019-02-01T10:14:00]e000: Error 0x85940001: Failed to execute EXE package. [0AE4:02E4][2019-02-01T10:14:00]i351: Removing cached package: SQLEXPRADV, from path: C:\ProgramData\Package Cache\9B9F0054139E678C8BB13A9BFF0FCD513015712C\ [02C8:04E4][2019-02-01T10:14:00]i000: ErrorPage Code: -2053898239 [0AE4:02E4][2019-02-01T10:14:01]i351: Removing cached package: AccessDatabaseEngine, from path: C:\ProgramData\Package Cache\277EA5EBCD18B8B98D82C9DC53399B4FE864CA51\ [0AE4:02E4][2019-02-01T10:14:01]i326: Removed dependency: {22c47c98-979a-45a2-b4a8-0952c50e0e2c} on package provider: {1E159C06-C1CB-372E-BBDC-A25DD78A7582}, package BrcmDocumentation [02C8:0264][2019-02-01T10:14:01]i000: Installing BrcmDocumentation [0AE4:02E4][2019-02-01T10:14:01]i301: Applying rollback package: BrcmDocumentation, action: Uninstall, path: (null), arguments: ' ALLUSERS="1" ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7"' [02C8:0264][2019-02-01T10:16:05]i000: Installed package BrcmDocumentation [02C8:0264][2019-02-01T10:16:05]i319: Applied rollback package: BrcmDocumentation, result: 0x0, restart: None
Any idea why?
Operating System = Windows Server 2012 R2 Standard
Patrick Loiselle
Hi Patrick ,
Please Check Compatibility of BRCM :-
Follow Below image
Please also check Installation Steps from below Wiki Link.
Wii Link :-
Avanti Khandalkar
Hi Avanti,
Thanks for following up with my issue. I finally found that Microsoft .NET Framework 3.5 Service Pack 1 is required before lunching the installation of BRCM. The BRCM installation was successfully completed.
