We've had a recurring incident where all wire links have automatically renumbered themselves back to the default tags Lxx. This is happened to the same user before on another project. Other uses have also reported similar behavior.
We typically tag these as 24V+A1, 24V+A2 etc.
Ive confirmed with the user that no pages have been moved or copy and no renumbering (re sequence IDs) has taken place, this has just randomly happened.
Bringing up the "Resequence Wire Link" window, shows Wire Link L19 has wire 919487 connected, however in the background you'll see it has wire 102 connected.
Is anyone able to offer any information on what might be causing this?
I've uploaded a backup of the project to:
https://www.bridgesltd.co.uk/BASINGSTOKE%20BMS%20SYSTEM.Prj
Kind Regards
*edit* what also appears to have happened is the same with the terminal numbers, these have been reset and renumbered and we also have duplicated terminals. I.e X2-1 and X2-2 are shown on pages 3102 and 3105.
Hi Adam,Please take back up of project and then share in that link . Wiki link for Back up of Project :- Regards,Avanti
Hi Avanti Khandalkar, Backup of the project is in my original message.
Please let me know if you require anything further.
Hi Adam,We need back up of project in .Prj format. You shared backup of project in zip format so for us its difficult to restore that project . Back up of project should be in .Prj format.
We are waiting for your update.Regards,Avanti
Hi Avanti Khandalkar, It was not a zip file. its definitely in .prj format.
Please see screenshot. I have also just downloaded from my link and it saves as .prj for me?
