So far , we have to BRCM programes.
When we use the "Race way size" button. One is no reponse. One is stopping work
What's wrong?
Hi Long Jun Deng,Can you confirm if you are trying to Run two instance of BRCM at the same time ?It is recommended that you run only one instance of BRCM at a time!Also can you confirm if you are facing this issue in a particular project or all the projects if you are running only one instance of BRCM ? Regards,Satish Saptasagar
Answer Verified By: Long Jun Deng
HI Satish,
This Problem occurs long time ago.
I run one BRCM on each computer not run 2 BRCM on one computers.
There also some strange problems sometimes.
Hi Long,As you have mentioned that this issue was faced long time ago, are facing the issue now. Also can you elaborate the strange issue that you face some times.Regards,Satish Saptasagar
Also I can not build equipments.
So How can we solve the problems now?
Re-install the software?
Hi Long,Kindly elaborate on the issue you are facing cannot build Equipment and with steps followed that lead to issue you are facing with Screen Shots, these details will help us better understand the issue you are facing.Regards,Satish Saptasagar
