I need help creating a report that will generate wire labels with the target 1 & 2 information for easy printing to a Panduit printer.
Hi Stephen,For your concern that you are facing, a report can be generated "Wire List Report" which has the details of the Origin and Destination details of the Wire, or you can create new Custom Report using "Wire List Report" and make changes to the report using Report Template Designer and you can try to get desired results. You can access Report Template Designer using below Wiki Link.Hope the above suggestion helps!Regards,Satish Saptasagar
