Message shows during Detect for datapath file "Query failed:A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote con"
Hi Shaliendra,Are you trying to connect to an Network Server where SQL Server is present ? If Yes than can you confirm if you have all the required access to the network server and if you are able to Ping the server.Also can you confirm if you have installed the SQL Server on the Network Machine to which you are trying to connect. Regards,Satish Saptasagar
